GE JVM1790 1000 Watts Convection / Microwave Oven Logo
Posted on Mar 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everything works except the Microwave. Even when you start the Microwave the table turns etc but no heat. Was making a buzzing noise then burning smell.
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Mar 14, 2011
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10845351
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
1helpful
My Whirlpool microwave model MH6130XEB-1 made a pop noise and now will no longer heat food. Everything else works fine, clock, timer, fan, turn table, etc. Is this a fuse problem?
It can be the fuse supplying the magnetron, or the magnetron itself which has failed. Another suspect is the high voltage capacitor in this circuit.
Don't try to fix this yourself as the internals of a microwave are dangerous, with high voltages even when unplugged.
1helpful
Samsong microvave does not heat, increase buzzing noise
You may have failing magnetron or shorted high voltage diode, but on some models, it is a failing capacitor on the controller.
We would need to know the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.
Please post a new help request with that and more detailed symptoms.
My GE Spacemaker XL1400 appears to be working, but is not
It could be an issue with the diode, high-voltage capacitor or the magnetron itself.
Please try following the steps from this article:
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
1helpful
2answers
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
1helpful
3answers
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
3helpful
3answers
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
How do I fix a Jenn-Air JMC7000 that does not heat up items?
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
2answers
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
