What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some
ovens are self cleaning During the cleaning process, the oven heats up
to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off
food and spills inside the oven, leaving ash that can easily be wiped
out. The oven door locks while it is cleaning to prevent the door from
being opened. Self cleaning ovens are better insulated than regular
ovens to keep the extreme heat inside.
Read
the owner's manual that came with your oven before you perform self
cleaning. Although all self cleaning ovens work basically the same way,
there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe
up any spills and messes inside the oven first, using warm water and a
mild soap. Ovens smoke more during cleaning when there is food inside.
Wash the inside of the oven door as well. Do not scrub the door
gaskets, just gently wipe them off. Damaging the gaskets prevents the
oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open
a window near the oven for ventilation. There is a certain amount of
smoke when you clean the oven. The dirtier the oven is, the more smoke
is created.
Turn
the control on your oven to "clean" and set the timer for 2 to 5 hours
depending on how dirty your oven is, and what the manufacturer
recommends.
Wait
for the cleaning to finish and the oven to cool before opening door.
When oven is fully cooled wipe up any ash inside. If your oven is not
completely clean, next time set the timer for longer. If your oven is
spotless you might want to see if you can get away with a shorter
cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
