SOURCE: T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
SOURCE: i have a pro form cross walk advanced 525x when i
the treadmill should have tension adjusting screws. they'd be on the back of the treadmill where the belt wraps around the rear roller, they're inset and you'll need an allen wrench to adjust them. the screws adjust this rear roller. you'll want to tighten them to increase the tension. they also straighten the belt. if your belt is too fat to the right, you'll want to turn the adjustment screw on the right clockwise to tighten and this will bring the belt over to the left. and vica versa for the belt being too far to the left.
SOURCE: When walking on my Image 17.5 S treadmill it has
hi,
you have to replace the treadmill belt. it become very lose that's why it not getting tighten when you adjust the hex screw.
ok
SOURCE: On my treadmill walking everything
The belt is slipping a bit... try tightening the belt a bit and you will be fine...
heatman101
