20 Most Recent Life Fitness F3 Folding Treadmill with Advanced Console Questions & Answers
Dear Sir:
I will try to help you, please see the videos, and do the steps with patience and carefully:
You must need some basice tools, Screwdriver, Dvom(Digital voltmeter) Hexagonals+Solder Iron+flux
Before to do disconnect the power cord, avoid ANY ACCIDENT!
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=KppD23xEl8U&feature=related
http://www.youtube.com/watch?v=E-q-uS4t6so
With this you can fix it.
If you need further assistance, please reach me.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA.C.A.
Life Fitness F3... | Answered on Oct 15, 2011
I am having the same problem as well!! Can anyone help?
Life Fitness F3... | Answered on Aug 22, 2010
yes, if the machine is still under warranty make the dealer come and fix the console. the only other thing it could be is a faulty electrical connection but it does not sound like it. The quality of the unit should be better!!! Hope this is helpful:) thx
Life Fitness F3... | Answered on Jul 24, 2010
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
Life Fitness F3... | Answered on Jul 19, 2010
The safety magnet/switch is not in the correct place. Make sure it is in the correct location.
Life Fitness F3... | Answered on May 07, 2010
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
Life Fitness F3... | Answered on May 05, 2010
First, check and make sure the safety magnet is in the correct place. If not, place magnet. If it is, then the safety magnet sensor, sensor cable, or the console is messing up.
Life Fitness F3... | Answered on Mar 19, 2010
It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
Life Fitness F3... | Answered on Feb 26, 2009
Life Fitness F3 Folding Treadmill with Advanced Console Logo
27 questions posted
Top Life Fitness Exercise & Fitness Experts
Vincent_G
Vincent_G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Life Fitness Exercise & Fitness
Most Popular Question
f3 basic problem console problem
  • Exercise & Fitness
