20 Most Recent Proform 695 LT Treadmill Questions & Answers
Console lights up but that is all. No beeps, not able to select speed, etc. Nothing happens when "button" pushed. Please help
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience.
2/9/2016 8:44:51 PM • Proform 695 LT... • Answered on Feb 09, 2016
0answers
FF appears on the display and treadmill will not
please follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
11/4/2013 11:07:13 AM • Proform 695 LT... • Answered on Nov 04, 2013
Need new proform treadmill 695 lt motor
go to www.fitnessrepairparts.com and God bless youMeasure the input voltage to the motor if there are voltage , the motor is faulty. mesuare the output voltage from control motor board, if there are NOT the control board is faulty.see the block diagram.God bless youac4388bf-31eb-4f87-ad43-9c0c10d012bc.gif2e4eb1b3-5071-4c47-9080-6b4922436639.jpg
4/5/2013 1:20:55 PM • Proform 695 LT... • Answered on Apr 05, 2013
Need a user manuel for 695 LT m# PFTL 69009
go to www.fitnessmanualsonline.com and download for freeGod bless you
1/8/2013 6:23:27 PM • Proform 695 LT... • Answered on Jan 08, 2013
The board will light up but thats all it will do..695 LT
1) replace batteries with new one preferible Hybrid rayovac rechargeable. with the same polarity,clean the contacts batteries2) tight the ribbon cable inside for keypad display board.3) adjust the REED swtich, see the diagram, test the switch for open or faulty, clean it, and tight the connector.God bless you1_7_2013_10_51_54_pm.gif
1/7/2013 10:52:00 PM • Proform 695 LT... • Answered on Jan 07, 2013
Calibrare distance
yes go to under the HOOD motor, and follow the steps for software calibration.otherwise go to the instr.manual and see the steps and proceed according.If you do not have the instr. manual go towww.fitness.manualsonline.comGod bless you
11/30/2012 6:23:31 PM • Proform 695 LT... • Answered on Nov 30, 2012
3 beeps on start up
1) adjust the REED switch see the diagram, clean it, and tight the plug very well2) adjust the speed sensor see the diagram, clean it, and tigh the plug very well.3) Try after you did the adjustment to RUN the software calibration for diagnostis, troubleshooting, and fix it.see the diagram attached.God bless you9_26_2012_12_57_06_pm.gif9_26_2012_12_57_34_pm.gif9_26_2012_12_58_10_pm.gif9_26_2012_12_58_30_pm.gif
9/26/2012 12:58:34 PM • Proform 695 LT... • Answered on Sep 26, 2012
Has an FF on the display sreen and it wont start
Please LUBE the Deck belt, this happen because the lack of maintenance according with the schedule.Maybe you have a deck wron and need replace see diagram2= Lube the Rollers bearing very well3= Adjust the Reed switch , clean it,tight the wires connector, see the diagram4= measure the voltage input motor, if there are the motor need REPAIR.5= Measure the output voltage board, for input voltage motor, if there ARE NOT the board is faulty.see the block. God bless you7_30_2012_9_52_10_am.gif7_30_2012_9_52_35_am.gif7_30_2012_9_52_54_am.gif
7/30/2012 9:54:19 AM • Proform 695 LT... • Answered on Jul 30, 2012
My proform 685 LT treadmill will only incline and decline when turned on. It does this automatically. The belt will not run at all.
Run the software calibration for diagnose, troubleshooting, and fix it.2) LUBE the deck belt, this happen by lack of maintenance, maybe you have the deck worn.3) lube the rollers bearing too4) measure the input voltage motor, if there are the motor need repair.5) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.God bless yousee the diagram 7_24_2012_5_13_27_pm.gif7_24_2012_5_14_48_pm.gif7_24_2012_5_15_27_pm.gif
7/24/2012 5:15:47 PM • Proform 695 LT... • Answered on Jul 24, 2012
Why does my treadmill try to stop when running on it?
Most of the problem is worn belt and deck.One reason is lack of lubrication between deck and belt/ This provide friction belt vs deck.Putting great stress to the electronic.By that reason the shut down is protecting the electronic circuit.Please do it. attached is the block diagram for to see how is work.2_14_2012_6_24_21_pm.gifGood luck. sincerely.ernesto cuaddramanagua, nicaragua. c.a.
2/14/2012 6:25:18 PM • Proform 695 LT... • Answered on Feb 14, 2012
Proform 695 LT Treadmill Logo
40 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
best treadmill
  • Exercise & Fitness
