Microsoft Windows 98 for PC Logo
A
Anonymous Posted on Mar 10, 2011
Whenever my laptop catches net(wi-fi) the system hangs...moreover warning is displayed that some of the applications are occupying more memory than normal..plz help i am using windows 7 ultimate and my laptop is lenovo z560..with intel core i3 processor and 2 gb ram
Jitender Dogra
Level 2:
New Friend:
  • Expert 40 Answers
  • Posted on Mar 10, 2011
Jitender Dogra
Expert
Level 2:
New Friend:
Answers
40
Questions
0
Helped
11841
Points
126
Check out in the task manager, which program is using more ram and let me know.
mostly, updating the drivers of wifi with the latest drivers from the vendor's website should fix the issue.
Phone loads the whole time without starting up
Install the application like Clean Master. It can be downloaded from google play store. It will clean the memory as well as the occupied space. Occupied spare and memory could be the reason of mobile hanging or late operation issue.
Enjoy !
tip
How to change WiFi security on my iPod Touch
<p>Are equipped with Wi-Fi connectivity that allows the device using wireless Internet networks. The iPod Touch can connect to open and secure Wi-Fi signals, and remember the details of the networks that had already turned on. If you enter the wrong password when connecting to a secure network, the iPod Touch still remember the password and try to use whenever it is within reach. The password must be manually placed back into the iPod settings to connect properly. <br /> <p> <br /> <p>1. Start the Settings application on the iPod Touch, tap the home screen. <br /> <p><br /> <p>2. Open the "Wi-Fi" page. The list of upcoming Wi-Fi will be displayed. <br /> <p><br /> <p>3. Touch the small blue arrow to the right of the Wi-Fi network that you want to change the "Select Network" list. A detail of the network is displayed. <br /> <p><br /> <p>4. Select "Forget this Network" button at the top of the screen. This removes all previously entered security information stored on the iPod Touch. <br /> <p><br /> <p>5. Tap again to the network in the "Select Network" list and enter the password security options on the pop-up box. Press the "Register" button to connect to Wi-Fi network with the security detail changed. <br />
on Jul 21, 2011 • Computers & Internet
tip
How can I permanently delete a Wi-Fi from iPod?
<p>Include network interface, the iPod Touch is equipped with a wireless adapter that allows hardware to join Wi-Fi networks by default, an iPod Touch love all Wi-Fi was never confirmed, this feature saves users the reenter the work of key network authentication and other parameters. However, in some cases, a user can have a Wi-Fi network to remove the memory of the iPod touch - for example, when the network configuration has changed. You can also prevent applications such as Safari Internet access. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that moment, the iPod Touch lost all memory you have connected to that network - past and configuration parameters. <br />
3helpful
I cant get an internet connection on this phone, do i need to set it up manually?
There are two ways you can connect to the internet over your phone. You can purchase a data plan from a company like AT&T which you can use anywhere. The other option would be to use your phone to connect to a wireless access point(WI-FI).
What are the differences? Wi-fi is usually free unless at a cofee shop etc but has a smaller area in which you can access(you have to be within a certain distance of the wireless router). A data plan cost money and is typically slower, however, you can use it at anytime as long as you have a signal on your phone.
You can click here to access the user guide for your phone.
If you have a data plan purchased and are using the SIM card they gave you then whenever you use a application on your phone that requires internet access it will connect.
If you go to page 83 of the manual it will go over the steps you need to take to enable Wi-Fi. In short, first active Wi-Fi
1) In Idle mode, open the application list and select Settings
? Wireless and network ? Wi-Fi settings ? Wi-Fi.
1) Then under Wi-Fi settings click Wi-Fi networks, select the Network you wish to connect to then click Connect.
Reference the user manual as it goes into more details about the features on your phone and how to use them.
Regards,
G33k
Does the eee 4g have a webcam built in
From what it looks like it does. This is the features of the computer.
Product Features
  • Integrated Webcam
  • Ultra-compact notebook with full QWERTY keyboard and 7-inch display
  • Powered by 900 MHz Intel Mobile CPU and pre-installed Linux operating system (compatible with Windows XP)
  • Over 40 built-in applications for learn, work and play
  • 4 GB solid-state flash memory drive; 512 MB RAM; 10/100 Fast Ethernet; 54g Wi-Fi (802.11b/g)
  • Connectivity: three USB 2.0; VGA output; microphone and headphone; Secure Digital card reader
Processor, Memory, and Motherboard
  • RAM: 4 GB
Hard Drive
  • Size: 4 GB
Cases and Expandability
  • Size (LWH): 6.3 inches, 8.86 inches, 1.3 inches
  • Weight: 2 pounds
tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
Wi Fi Connection
hi
u need to make sure that you are in a secure connection and moreover its asking for a gprs connection because its loosing the wifi connection. The best idea would be try some other wifi network i am sure you would be able to surf webpages.
enjoy
2answers
Gateway laptop hang issue
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
WEBCOM & Wi-Fi do not working
hello sir my laptop is compaq model no v3424au my laptop prblm is just start on white display... nd hang on white display..nd my laptop is not proper working... pls help me. i check my laptop near service cente...but i will not proper satisfied. This prblm is allready my laptop here.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
