Texas Instruments TI-30XA Calculator Logo
A
Anonymous Posted on Mar 08, 2011
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Mar 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
27625
Points
65
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
How do I convert 0.1 into a percentage using a TI-30X-IIS?
Using any calculator, multiply it by 100. I think of "per cent" is "per 100" so you need to move to decimal two places to the right or multiply by 100. In this case, either way, we get 10%.
Any questions, let me know.
Good luck.
Paul
How do I convert decimals to fractions on the TI Math Explorer (No numbers associated with it - i.e. TI - 15)?
The way it works is as follow. If a result is displayed as a fraction you can convert it to its decimal representation. If you do nothing after the conversion, you can revert the decimal representation to the fraction.
1helpful
How do i charge my TI-30X IIS calculator
You don't. The 30X IIs runs on both solar power and a 2025 lithium battery. If you need to replace the 2025 battery, see this.
1helpful
How do i go from dms to decimal degrees with my ti-30x IIs
Press the key that is marked with a small circle, an apostrophe, and a double quotation mark. That is the DMS key. You can use it to convert from Decimal degress to DMS and back.
Can you do complex fractions on the ti 30x IIs
No. You will need to get at least a TI 83 or TI 84/84+.
4helpful
How do i convert Decimals to fractions on the TI30X IIs calculator. I need the Button sequence Please!
2nd [F<>D]. F<>D is on the PRB  key, diagonally down and right of the 2nd key. The conversion may not work for numbers with more than three nonzero digits to the right of the decimal point.
7helpful
2answers
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
I just bought a texas instruments TI-30X IIS Calculator. How do I reduced improper fractions with no mixed numbers. What keys do I press. For example: 3 6/8 X 7 1/3 = ? How do I find the answer?
if you want to use your calc for this you would have to put it in as the operations to change the mixed to improper fraction i.e. input exactly as "((8*3)+6)*((3*7)+1)="  remember?  take denominator times whole number plus numerator and put over denominator to convert from mixed to improper... hope this helps
3helpful
Texas Instruments TI-30X IIS Calculator '+/-' sign
it is just a (-) symbol and it is beside the decimal point (.) button
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
