Are you referring to Eco Drive E820? If you do here are the simple steps that can help you.
-Pull the crown out one notch
-Rotate the crown to align the mode hand with time/calendar[TME] as indicated on the mode sub dial.
-Pull the crown out two notch
-press the upper right button above the crown.
-Rotate the crown to adjust the time.
For step by step procedure with visual, click on the link.
I hope this will help you resolve the issue.
Thank you for choosing Fixya.
SOURCE: cant set time
go to citizenwatch.com, go to faq and click on "how can i get instructions if i did not receive an
instruction booklet". then you enter your movement caliber number and the rest should be self explanitory. Hope this works, i'm sure it will.
