I have the 5kw Honda and have no problem, but I have never tried to run 5,000 watts either. It is reaching max rpms? Air filter clean? Good fuel? Oil? Have you run it much, or does it sit? How do you measure the wattage? Add up a bunch of things like, skil saw, pump, fridge, etc? Let's see, skill saw at 13 amps x 120 volts =1560 watts. Fridge probably idles at 7amps, starter windings use 10 or so amps, tv, 500 watts, computer, I would not run anything electronic with a genny, unless I had a spike protector on it. Check it out, hope this helps.
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
