Computers & Internet Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The volume is cut off on start up and when playing video the machine displays picture but the sound/volume is off
Shahzad Waseem Akbar
Level 3:
  • Master 746 Answers
  • Posted on Mar 04, 2011
Master
Level 3:
Answers
746
Questions
0
Helped
272404
Points
2750
Reinstall your sound driver.
Good Luck
1helpful
2answers
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
2helpful
I am trying to find out what the blue symbols on the function keys of my sk 9020 keyboard stand for
The blue keys serve as a secondary function for your volume control, monitor controls and pause play fast forward rewind (in media mode). In order to use the blue keys that are numbered from F1 to F12, you must depress and hold the Fn key that is located at the bottom left side of the keyboard. Here is a way to test it: Open up any file that plays sound for longer than 1 minute (60 seconds). While this file is playing, hold down the Fn key and simultaneously press F8 and listen to the volume get louder or Fn and F7 together and listen to the sound get lower. The picture of the crescent moon F1 will adjust the brightness of your screen. F2 will magnify your screen. F3 will take you to your email. F4 will take you to your internet home page. F6 will mute the volume. F7 will lower the volume. F8 will raise the volume. F9 will rewind your video playing. F10 will stop the video. F11 will pause or play the video. F12 will fast forward the video.
1helpful
How do i turn off the message keypad noise that happens when im typing a text message?
Sounds
• To set volume for media and videos, from the home
screen, touch Menu > Settings > Sound &
display > Media volume.
• To play tones when using the dial pad, from the
home screen, touch Menu > Settings > Sound
& display > Audible touch tones.
• To play sound on a screen selection, from the home
display > Audible selection.
Good Day.I have a laptop product of toshiba and the problems is all speak, i can't it to play music but i can play video without sound only the pictures will be joy.What will i do to regain the sound?
Go to Start - Control panel - Sounds and audio devices - Check volume control for speakers (Advanced box). Also check Correct speakers are selected.(Advanced box)
1helpful
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
1helpful
2answers
Volume auto turns down
hi i downloaded windows 7 and now my touch volume control does not work what should i do
While i am play a dvd my pc keeps giving out a cutting sound
A cutting sound like its interrupting or more like a high Pitch sound more like squeeking?
*if its interrupting, you might need to stop anything else whyle running your DVD (ie: internet, downloading, uploading, or anything else means your memory is being used with something else.
*if its high pitch or squeeking, check your microphone's Volume from your volume options by double clicking on your volume icon on your lower right side and either minimize or muteyour mic.
Xbox picture gets cut off on the sides
try fiddling with the tv menu. most tvs have the zoom function now and also the ratio function. try testing those configurations starting from the default. make sure you have the zoom function set at 0 before fiddling with the ratio aspect.
Sound problem on new Aspire
You can check already the audio setting in your dvd software maybe the volume is low or mute. Click Start, accessories,entertainment and volume control adjust the volume to higher or look if the volume is mute
2answers
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
