Pride Mobility Products Quantum Jazzy 500 Electric Wheelchair - Used Logo
Anonymous Posted on Mar 03, 2011
Pride jazzy quantum 1420. working fine until today. when turned on, lights by joystick all flash on and off repeatedly. chair does not move. Any suggestions?
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Mar 04, 2011
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288867
Points
1801
Could be in sleep mode try pressing the on/off button twice to get out of sleep mode if that doesn't work then you have a joystick problem and it needs to be replaced Hope this helps
  • Anonymous Mar 04, 2011
    I left it overnight
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
THE BATTERY LIGHT CONTINUSLY SCROLLS FROM LEFT TO RIGHT AND CHAIR WILL NOT MOVE
Turn on Joystick and push horn twice, you are in locked mode. If this didn't work then turn Joystick on push gimbal forward until you hear a beep, then move the gimbal back until it beeps you are now unlocked. Gimbal= what you push to go left right forward or back on a joystick.
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
7helpful
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
1helpful
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
I charged the batteries for 12 hours and then turned the chair on. The batteries appear to be bully charged, but the chair will not move. The joystick is flashing 8 times. Apparently a joystick fault? ...
There isn't too much you can do to fix this problem. You will have to have the joystick replaced. If Medicare paid for the chair then they will pay for most of the repair costs contact the provider that sold you your chair to have them order a joystick from Pride and repair the chair for you Hope this helps
2helpful
Speed lights flash alltogether at the same time chair will not run
The chair is in sleep mode or lockout mode. To unlock-- turn on the chair, immediately push the joystick straight forward until you hear a beep then push it straight back until you hear another beep then release to center. This should unlock the joystick. Turn the chair off then back on and you should get normal operation Hope this helps
1helpful
My father has i believe a jazzy 6 wheelchair and the lights keep flashing. There is no sequence of flashing, just flashes away without a break. The horn works, that's all. Wheelchair will not move at...
Bobby check that the chair is not in freewheel first (you can push it and it will roll freely). If it is not in freewheel, try this--- turn the power off on the joystick then turn it back on and immediately push the jostick full forward until you hear a beep then immediately pull the joystick to the rear until you hear a beep then let it go to the center position. If the chair is in lockout it should take it out and the chair will operate fine. Now if that doesn't work I dunno. No seriously a continuous flash as you describe is the only indication of a lockout that I know of for the Pride chairs. If Medicare bought dad's chair then you can get a service company to fix it for him and they will bill Medicare for the cost of repair. Medicare will pay 80% of the costs and if Dad has a supplemental policy it will cover the 20%. Contact Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
