20 Most Recent
Pride Mobility Products Quantum Jazzy 500 Electric Wheelchair - Used Questions & Answers
How do yuou reset Edge series chairthe quantum Q6
Turning it on and off will reset everything, but I am not sure what you mean by resetting???? The chair is configured for normal operation at the factory and cannot be changed by a layman, unless you buy a hand-held programmer for the particular controller your chair uses. Some/most technicians have these and can change the factory presets using it to reprogram the controller.
Lights scroll from lt to rt ant lights around joy
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Pride jazzy quantum 1420. working fine until
Could be in sleep mode try pressing the on/off button twice to get out of sleep mode if that doesn't work then you have a joystick problem and it needs to be replaced Hope this helps
I have a quantum 6000
Jal Check with your provider and ask them for a pair of Elevated Leg rests for your chair. They might have to install the holders for the leg rests but that is an easy job. And they are fairly inexpensive and can be put on and taken off easily. Hope this helps you
I am loosing green lights
The green lights will gradually go away as your battery is being used, this is completely normal. You batteries should last for around 5-10 miles of use. If you find that your battery light falls into the red after only 2-3 hours of use and you have been charging the batteries every night for at least 8-10 hours, contact your manufacturer for service.
