Put four AA batteries into the battery housing located on the underside of the Wii Balance Board. Insert a Wii Balance Board compatible game into the Wii system. Select the "Disc Channel" on the screen with the Wii remote, and choose "Start." Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons. Turn the Wii Balance Board upside down. Remove the battery cover under the balance board to reveal another sync button. Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
Follow these instructions here to sync the Wii Fit Balance Board: http://www.nintendo.com/consumer/systems/wii/en_na/setupBalanceBoard.jsp#Synch
SOURCE: wii fit
You'd have to press the sync button on the board and if you pop open the little flap on the front of the Wii, there's a red button to push there too.
SOURCE: wii fit board wont sync
I have a wii fit board that the power button won't stop flashing I have tried to reset the sync button changed batteries twice still not working.
SOURCE: wii fit board blue light flashing, changed batteries and reset.
open panel on wii console and press configure button console to reset it
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
SOURCE: new crown compatible wii fitness
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
