Reset overtemp thermostat should be small round disk attached to drum with a little red button.. Press firmly should reset ..
tried this but still not heating,i think new heating element may be faulty,how can i check this,advice please.
Do you know how to use multi meter ?? It would give you the answer immediately .. Multi meters are available very cheap.. Quite easy to use..... If you have replaced element recently is it installed correctly , does overtemp thermostat work. ? Besides main control these are the only 2 items controlling heat!
tested thermostats ok. heating element ok. where is the overtemp thermostat located?
sorry not been back to you been on few days hols.
Overtemp should be in a fixed position mounted on outside of drum casing... Follow wires from element..
checked this out ok.still not heating ,could it be the timer?
