No solution possible, given that the air ducts going up over the patio doors are quite an eyesore. This building is entirely fieldstone outside, so either the patio doors or windows above them are the only way to go in or out.
We will return the unit and get instead one that can be placed in the upper window and activated by remote control. Thanks.
SOURCE: DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
SOURCE: Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
SOURCE: How do you install Danby
This whirlpool manual will give an idea: 10000 btu portable
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: we bought the danby Premiere
check service tag on unit what is the amp rating on the unit does it exceed your breaker size??
