Panasonic KX-TM150B Digital Answering Machine Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to turn on machine from a remote location
Anonymous
Level 2:
  • Expert 225 Answers
  • Posted on Feb 25, 2011
Anonymous
Expert
Level 2:
Answers
225
Questions
0
Helped
117968
Points
655
Call your KX-TM150B answer machine, it will answer after 15 rings if it has power but the answer function is turned off. The greeting will play and the answer function will turn on. I have included a link where you can download the manual.
http://service.us.panasonic.com/OPERMANPDF/KXTM150B.PDF
Where is the reset button on the veon remote?
The location of the reset button on a Veon remote control may vary depending on the specific model, but in general, the reset button is usually located on the back of the remote control. Look for a small, circular button that may be labeled "Reset" or "RST".
To reset the Veon remote control, press and hold the reset button for a few seconds until the LED light on the remote control turns off and then turns back on again. Release the reset button, and the remote control should be reset to its default settings.
If you're unable to locate the reset button on your Veon remote control, consult the user manual or contact the manufacturer for assistance.
NED 8700 smart button location
a marantec ned8700 has no smart button you have to open the remote n remove the battery then connect the programming 3-prong cable to the terminal on the side of the remote (under the rubber cover) the with a flat screwdriver short out 2 of the prongs one must be the center prong. press and hold the button on the remote that is active, in 2 seconds code will change. elease the button after the light illiminates continuously then remove the programming cable/prongs and replace battery n cover then press n release p button on machine till only 7 lights up take remote hold it 3'' away from button and press button on remote to program for 10 secs release then push p button on machine once, 8 will light up and your set to go
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
How do I receive a fax?
If the machine is located away from the telephone, pick up the handset and dial 25 (the remote receiving ID) to receive faxes (remote reception).
bullet_s.gif If you use a rotary pulse line, temporarily switch your telephone to tone dialing. For details on how to switch to tone dialing, see the instruction manual supplied with your telephone.
bullet_s.gif If you have an answering machine connected to the machine that can carry out remote control operations, the security code for this function may be the same as the remote receiving ID. In this case, change the remote reception ID in REMOTE RX ID in REMOTE RX in RX SETTINGS under FAX SETTINGS.
3helpful
Wanted to know if i can check messages by calling in
CLICK HERE for the user manual.
The following is on Page 19....
REMOTE ACCESS
You can access your answerer from any touch-tone phone
by entering your 4-digit security code (the default security
code is 0123). The remote functions do not work with rotary
or push-button pulse-dialing phones. You can cut out the
wallet-size remote card near the back of the User’s Guide
so you know the touch-tone commands when you're
picking up messages from another location.
To access your answerer:
1. Call your telephone number.
2. After you hear the beep that follows the greeting,
enter your 4-digit security code. To bypass the
greeting, you can enter your 4-digit security code at
any time while the greeting is playing.
3. The unit plays the remote menu after the correct
security code has been entered. Menu selections can
be made at any time while the menu is playing.
NOTE: The unit answers on the 10th ring when it is
turned off or the memory is full. To access the
answerer, enter the 4-digit security code after the
beep. If memory is full, play messages and erase
some of them to restore memory. If the answerer is
off, press 2 to turn it on.
NOTE: After the unit plays the remote menu, it will
wait several seconds for a command, then disconnect
Thank you for using Fixya - a FixYa rating is appreciated!!
How far can the condensor be located away from ice machine
Their web site has all your answers. Their tech support line is worth the wait. 1-800-233-1940.
I usually don't exceed 25 feet. If it is a straight up install, that is, the remote is on a roof, you may have to install traps to ensure proper oil return to the compressor, Otherwise, it will lockup on ya.
Pick up calls from another location
Manual - http://support.radioshack.com/support_phones/doc65/65505.pdf
SECURITY CODE
label is located on the bottom of the system. Enter the security
code after the system answers and sounds two tones. Within 7
seconds, enter one of the remote commands
OPERATING THE SYSTEM FROM A
REMOTE LOCATION
Dial your phone number. Even if the system is off, it will turn on
and answer after about 10 rings. After the system sounds a
tone, enter your remote operation security code. Enter a remote
command (see “Remote Commands” on Page 19). When you
finish, press 5# to end remote access.
REMOTE COMMANDS
Note: When listening to messages in remote mode, there is a
pause during playback every 2 minutes and 40 seconds. Press
0–9, #, or * to continue playing the message.
Press To
1# Play new messages.
2# Play all messages.
3# Delete the current message.
4# Repeat a previous message.
5# Stop and exit.
6# Skip a message.
7# Turn on/off the system.
8# Record an outgoing message.
9# Record a memo.
0# Monitor the room.
Hope this Helps... Have A Nice Day... :)
Panasonic KXFP145
when I sent a fax via Satellite communication, I got error 503 for few customer - it seems I need to change ECM at the remote site .. any advice
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
