Hello Brenda
Where do you want to hook your ONKYO and with what you want to connect it to.
There are several steps and a lot of devices can be connected to the Onkyo.
1 Speakers are to be connected on the rear side of the device. as it shows in and on the Instruction manual If you have it.
And for other devices each device has its way of connectors.
Optical to optical and RCA to RCA ...
IT depends on What kind of devices you have.
Hi Quintin, I would suggest that you disconnect your speaker and reconnect it making sure that the speakers connection is correctly made. If so try swapping the right and the left to see if its the speaker that is causing the problem. You can email me at [email protected], Thanks, JT
set the input selector to the proper component sources your using.
set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
It will shut down if you have the speaker wires touching, or the wrong polarity of your connected speakers. Check the wiring and connect one speaker at a time. (turn off to connect)
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
