Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
Posted on Feb 25, 2011
Location of cielo whirlpool bath part number 6871 AEF-U326 . on & off switch . Thank you .
Jacuzzi tara o ring
What is the o-ring used for? Where is this o-ring located and what is the function of the o-ring?
US Parts Center
1helpful
Replacing defective pump switch
The air switch on a bathtub is located in the bath pump. Your description sounds like you are asking about the air button which is located on the top lip of the bath tub.
Click on those links to see your options for whichever part you need.
Rod
U S Parts Center
888-521-6183
Mar 17, 2013 • Home
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Were is the starter switch located on corner jacuzzi tub
Depends on the make of your bath, alot of baths has a crome button on the corner of the bath, flush with the bath top. When you press this it pushes air through a hose and the pressure of the air hits a pressure switch on the motor which turns on the motor.
Mar 29, 2011 • Home
I cant find my serial number
Take it is a whirlpool bath? if so, the serial number can be located just above the motor end of the bath
Feb 28, 2011 • Home
Where can i get an Air switch 6871-aeo-u626
I assume that number is off the old switch. It is next to impossible to locate parts such as an air switch that way. What you generally need to know is what size the orriface is to fit the tubing, if it is a double or single pole switch, how it mounts in the control, etc. Based on those answers you would purchase a generic replacement.
Try this catalog if you like (**Warning** It is a large file: 20+ MB) and if you can ID the part(s) please contact us thru www.arrowpools.net for a quote on it.
Whirlpool spa bath touchpad wiring
you need to acquire a wiring schematic from the manufacturer for your tub,....get all info you can think of i.e. model#, serial# name, etc. so when you reach a human on the phone, you can give them all of this required info they'll need to get you the right info you'll need to re-wire this thing,..good luck
How to wire a jacuzzi whirlpool tub? What to use for wiring, timer etc?
get an electrician. you need to follow the code for the size of wire to use based on number of amps of the motor and how far away the pump is from the power outlet.
4helpful
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
