You can use spray-on oven cleaner, such as "Easy Off" or any similar store brand. Do not use oven cleaner on Aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubber handles. Wear rubber gloves when working with oven cleaner. It is a very powerful cleaner and can burn your skin.
- Put the pan in your empty kitchen sink.
- Spray it on generously with oven cleaner.
- Leave it overnight, 8 hours or so.
- In the morning thoroughly rinse and wipe all the areas you sprayed, including the sink.
You should have a clean pan and a clean sink. Refer to the oven cleaner's label for further instructions and safety hazards. Choose the type of oven cleaner that suits your needs. In my experience, "Fume Free" oven cleaners take longer and don't work as well. Seemingly, the more noxiously fumed cleaners, ie ones containing Lye (Sodium Hydroxide), work better and faster.
This works for porcelain coated pots/pans, stainless steel, steel, glass, etc. Do not use oven cleaner on aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubberized handles.
I have contacted the manufacturer and they ae sending me new pans. Thank you.
