20 Most Recent
Toastmaster 1142 Bread Maker Questions & Answers
The bread sticks in the
Try using 1 tablespoon less liquid using the same recipe. If it still sticks try using a total of 2 tablespoons less liquid.
I LOST THE KNEADING BLADE
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the words KNEADING BLADE DOUGH PADDLE as your Internet search. Google Search is better. Google Product Search is best.
Example: If you owned the Fredericks Home Bakery model KHB-178 you would enter your search as
FREDERICKS HOME BAKERY KHB178 KNEADING BLADE DOUGH PADDLE
Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
I just inherited, by virtue of moving, into a home
FixYa does not allow for the distribution of the actual documents but I can advice you on how to locate one yourself, that is to say if there's even one available for download on the Internet. Unfortunately not all original custom recipes for over 2000 individual breadmakers made over the last 25 years are.
Here's what you do:
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the words MANUAL RECIPES COOKBOOK + the abbreviation PDF to perform an Internet search. Google Web Search is best.
Example: If you owned the Fredericks Home Bakery model KHB-178 you would want to enter your search as:
FREDERICKS HOME BAKERY KHB178 MANUAL RECIPES COOKBOOK PDF
Hope This Helps & Happy Hunting!
If you're unsure what your model number is:
My toastmaster bread machine 1142,
The next time you make your bread use the same recipe but use 2 table spoons less liquid. Having the paddle come off in the bread is not abnormal. If the bread sticks to the pan again let me know
[email protected] Sometimes my paddles stay in the loaves sometimes they do not.
While the machine is kneading
It sounds like your belt is slipping. All bread machine operate off of an electric motor and drive belt and they do wear out.
Do dry ingredients go in
If you aren't using the timer feature it doesn't really make any difference but normal sequence is liquids first, then salt, oils, etc., the last 2 things to add are the flour then the yeast. If you need a manual for your machine just email me at
[email protected]
It will have detailed info on how to use your machine.
I accidently unpluged during using it ha about 1
If baking had not started then you can finish it in your regular oven. Bake it in a preheated oven for 30-45 minutes or until done. You'll know if its done if it sounds hollow when you thump it. If baking already started then you will probably have to discard it and start over.
Do they still make this
Your pan and seal are starting to disintegrate. I have a older model toastmaster in almost new condition. If interested I can sell to you via paypal. You can try it for 7 days and if you don't like it you can return it. Let me know if you are interested. It's not a 1142, it is a toastmaster 1170S, "corner bakery" model,,,,supposed to make butter too but I don't have the little butter lid, but you could still make butter with it. Toastmasters are my favorite too. They are quiet and have heavy duty pans.
[email protected]
I need to know the
unless you are using the timer feature you can add everything at once, choose your program and push start. If you are using the timer feature let me know and I'll tell you how to handle that. As a general rule add the yeast last.
