My AC unit blue indicator light flashes continually. The manual states it is suppose to just light up. Also the temperature reading is always the same no matter the temp in the house. The unit blows cold and does work but it appears I can't set anything as the temp is always the same even when the unit obviously cools the room. The side of the display states E01????.
the manual doesn't help in regards to problems. Also the unit to continually cycle from AC to Fan every 5-10 minutes.
One of these is a power light. It typically remains on while the freezer is in use. No light means either a blown bulb or no power. The other is associated with the thermostat. But it does NOT indicate that freezer temperature is appropriate. Flickering appears to indicate the bulbs are simply failing. The bulbs are neon, I think, and are not cheap. Some might try replacing such with LEDs. I have seen comment that the bulbs are not long lasting. www.manualslib.com has numerous danby freezer manuals but I do not know your model. Have a look.
I have a DPAC 1200068 air conditioner and the red light keeps blinking and I need to know how to shut it off so it flashes when it is suppose to and go off when it is suppose to.
This sounds like it could be a power supply problem. It may be very simple. I think I would first just unplug the unit, open it up, look for the PS connectors, and check/wiggle them to make sure there is good contact.
I went to the Danby's website: https://www.danby.com/
And I was unable to find any service or owner's manuals in PDF format. The site does however have a locator for service shops. Good Luck! da Marty
Here's a link to a site that has a free copy of your owners manual available. Just scroll all the way down and enter in the code shown and you'll be able to download the manual instantly.
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
