If they get stuck in the back, you could have a bad fuser.
If paper comes out the back and goes up towards the delivery assembly and then
starts to fan fold...the delivery assembly needs to be cleaned or replaced.
When you print the paper comes out the back of the printer thru the fuser and
up towards the delivery assembly and then into the exit tray. those are the rollers at the very top of the printer, in the back that need cleaning or replacing. A little alcohol on a cloth works pretty good.
Testimonial: "Quick response - thanks!"
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
To manually remove paper pull on the paper with both hands being
careful not to tear the paper while pulling it. If you're unable to get
to an edge of the paper that allows you to pull it you may need to
manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As
mentioned earlier it is inevitable that you will encounter at least one
paper jam during the life of your printer. However, if you're
encountering frequent paper jams following the below steps can help
prevent paper jams from occurring.
