20 Most Recent
IBM Infoprint 1332 Laser Printer Questions & Answers
Error message: remove paper standard bin
If you look to the printer, on the way out there is a small flag that usually gets stuck and then you get the error "Remove Paper Standard Bin". Simply look at the image below to see which flag I am taking about. Make sure it didn't came out of it's holder and if it did, just fix it back in so that when you lift it up it falls down easily. In my experience this always fixed it.
http://tinypic.com?ref=30xfqrl" target="_blank">
http://i52.tinypic.com/30xfqrl.jpg" border="0" alt="Image and video hosting by TinyPic">
Ibm 6400-008 with P62 error
P-62 error is DC program not valid. The printer cannot find the controller program or the validation checksum is corrupt.
You can try to reseat the flash (memory simms) but it probably will not help. You need to re-download the program (microcode) to the machine and if it still fails replace the flash with pre-writen flash.
If you need a copy of the microcode and instructions on how to load let me know here (I will try to keep an eye on this post)
Hello
I am getting a paper
DEAR SIR,
Some print media, although they may conform to size and weight specifications, may not perform to your expectations. Print quality, jam rates, fuser life, and output stacking can be affected by the printing environment (temperature and humidity) and characteristics of the paper (structure, moisture content, smoothness or thickness);
Duplex printing is not supporteD
Using Auxiliary tray is recommended
HOPE THIS HELPS....
Thank you sir,take care
Constant paper jams
Open the printer and with a blower clean it thoroughly.This resolves the paper jam issue many times.
