RCA RT2910 Theater System Logo
A
Anonymous Posted on Feb 18, 2011
I just purchased an RCA RT2906 home theater system and am experiencing audio delay when switching channels on my Verizon FIOS cable box. It takes 3 or 4 seconds for the audio to kick in each time I switch channels. I am using HDMI cables. Any help would be appreciated. Thanks. Martin
Anonymous
Level 2:
Sergeant:
  • Expert 180 Answers
  • Posted on Feb 18, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
180
Questions
Helped
64958
Points
539
You can try using an optical cable but you will likely run into the same issue. Each time you change the channel the digital stream is interrupted. The HT likely takes this long to start the decode process.
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
1helpful
I have a Verizon FIOS DVR connected to the Samsung receiver. After watching TV for a period of about 30 minutes or so I start to get a delay in the volume coming out of the speakers compared to the picture...
common problem, trouble is that the receiver cant keep up with the dvr box. try this, dont use audio from your dvr into your reciever, take the audio out from the tv, and go into the receiver, now the sound is after the picture and should catch up with itself.
My RT2906 sound keeps cutting in and out. It works fine on some channels and worse on others.
Wonder if this is the same problem that the RTD325 has. It's a shame that RCA Service acknowledges only 2 complaints on the 325. Walmart is still selling the 325 as of Feb 24, 2010
2answers
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
We have a samsung ht-z515 home theater system and a new samsung ln-t4669f hd tv and I'm trying to hook up the system so we can hear it through the speakers. We are on Verizon Fios and I bought a Fiber...
Make sure the TV is set to output audio to the digital optical port. Then make sure you have selected the proper output mode on the home theatre. Unplug the optical cable from the back of the home theatre and see if the red laser is on (don't shine it in your eyes! :))
How to use DVD player along with cable box wih this tv
The audio out jacks in the back of the cable box can support up to 5.1 channels of audio to a home theater system. Take the DVD player and plug it into the TV with only the video cable and the audio cables into the theater syste. If you have and questions you can ask and if pictures are needed than I can post them.
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
