To remove some links: If you don't have special tool, at least you have to have something really hard and thin (like the pin you use to post notes on the cork board). Put that pin in to the tiny hole between links where the bracelet pin is and then press/push it forward (follow arrow direction as shown on the inside of the bracelet links.) When the bracelet pin comes out at one end, pull it out of that end totally.
After removing one links, connect the two links next to each other by placing the bracelet pin back into the hole and push it to the other end.
To add some links: You have to have spare links and do the same way with the pin to attach more links.
