Lexmark C534dn Laser Printer Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexmark c534dn unsupported cartrige - Lexmark C534dn Laser Printer
ONE-Touch-Solution
Level 3:
  • Lexmark Master 1,679 Answers
  • Posted on Feb 15, 2011
ONE-Touch-Solution
Lexmark Master
Level 3:
Answers
1679
Questions
Helped
405125
Points
5442
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
  1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
  2. Make sure the correct toner cartridge is installed for this printer model.
    1. Check Lexmark for a list of compatible cartridges for your printer.
    2. If the wrong toner cartridge is installed, remove it and install the correct one.
  3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
    1. Turn off the printer.
    2. Reseat the toner cartridge.
    3. Close the lid.
    4. Power the printer back on and check the display.
  4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
    1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
    2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
  5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
2answers
Lexmark C534dn has a blank display and a red light. How do I get the display back and a green ready light?
If display is blank you likely have a bad display or some other problem that will require replacements parts. Keep in mind that on Lexmarks the control panels are keyed to the formatter so you cannot just get a used panel from another printer, you must purchase a new one.
960 service memory error-a lexmark c534dn what is wrong how to fix?? Gloria
The printer memory is failing. RAM soldered on the system board is bad. It would be best if you contact Lexmark Technical Support for proper assistance.
Lexmark c534dn is printing on the left side of the page only.
toner is going to empty, for instant solution take out toner cartridge and shake it for some time, then put it back to printer it will resolve your problem for a while but ultimate solution is replacement or re-fill.
Unsupported cartrige lexmarkz735
Hi there
You have been lucky if you have been using re-cycled cartridges, most times they not work with Lexmarks or Brother Printers.
You must have been Lucky to get some good ones.
All the best Pineworks
I have a lexmark x8300 printer (all in one). in the past I have been successfully using refilled black no.32 and colour no.33 cartriges. However it used to say 'low ink replace cartridge' but it had always...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
3helpful
Pringed Pages are coming out with yellow and blue smudges on edge
I have also had this problem which I solved by changing the photoconductors of the colours shown.
you can try this.I am not sure if that is the best solution but it solved my problem
Faulty System Board Part No. 40X3618
Just take off the back cover and unplug the wires. Take out the 7-10 screws and then put the new one in just like you took out the old one. Its very easy.
Cartrige
Are you using a refilled cartridge or one that was not manufactured by Lexmark?
Sorry for the bad news that follows.
Extracted from Lexmark’s web site: www.lexmark.com
Lexmark End User Statement of Limited Warranty for Supplies
Lexmark International, Inc. Lexington, KY
Not Covered:
Warranty Service does not include repair or exchange when the problem results from accident, disaster, misuse, abuse, non-Lexmark modification (including refilling, tampered with in any way or remanufacturing), improper storage, malfunctioning equipment, laser print cartridges which are simply empty as a result of normal use, or normal wear and tear. Character or page yield is also not covered by warranty service, as it is influenced by customer application, printer contrast settings, operating environments, printer condition, and paper type.
Don
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
