A
122.05 or
122.06
Fuser error indicates that the printer/MFP
has detected a problem with the fuser unit. A service call will probably be
required to solve this issue. However, certain rare occurrences, such as a power
fluctuation or a static discharge in the vicinity of the printer/MFP, can cause
a false
122.05 or
122.06 error message to
appear. In such cases, the error is only temporary and can be easily resolved
without service.
Try perform the following steps:
- Power off the printer/MFP, wait 30 seconds, and then power it on again.
Did
the error message return?
- If possible, connect the printer/MFP's power cord directly into a grounded wall
outlet. In rare instances, a surge protector, extension cord or uninterruptible
power supply (UPS), can generate false error messages. Verify also if the
printer works on a 110 or 220 volts source.
Make sure that the power outlet matches its working voltage rating.
If this doesn't resolve the error, I suggest you contact Lexmark Technical Support.
