You probably lost the package and the instructions sheets that came with it new. You could probably look up their web site online and look for support section. Have your model number ready. They may have a download of the manual - with the codes sheet for a LOT of tv's. I hope that helps.
yes they are. This is you need to undrstand how it's work. Your TV or DVD or whatever you try to connect, they azll have a romote controle number that they will never change. ex: if you TV remote controle number is 0143, you will alway use this number to be abble to controle it. o, if you have one remote then you change of remote because you break it or change it, you will still use this number 0143. This number is the code that represent the frequensy needed to work. if they do not match nothing will happen.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
