Minolta QMS PagePro 9100 Laser Printer Logo
Posted on Feb 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer get a H-sync error on read out and stops printing.
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 22, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1914023
Points
11960
Replace the print head which house the LASER and polygon motor. mite check connection to main board and print head.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
How TO Fix Hp Printer Error 0x610000f6?
Well known issue and easy fix
Error Code '0x610000f6' Message Displays for HP Photosmart ...
support.hp.com > ca-en > document
Error Code '0x610000f6' Message Displays for HP Photosmart Plus All-in-One Printers (B209a, B209b, and B209c) · Issue · Solutions · Solution one: Turn the printer ...
Different Ways for How to Fix HP Printer Error 0X610000F6
www.printerfixes.com > Brand Related Issues > HP
HP Printer Error 0X610000F6 also known as Carriage Jam Error occurs very often in the Photosmart HP Printers. When a jam occurs in the printer due to paper scraps or due to any other reason, the printer stops working and it doesn't print any document.
VIDEOS as well
https://www.google.com/search?q=Hp+Printer+Error+0x610000f6&rlz=1C1QJDB_enCA643CA644&oq=Hp+Printer+Error+0x610000f6
I'm getting error e02 it does have paper
Canon Printer E02 Error is a mechanical fault, that cases up to the printing process of a printer. This technical error can happen due to overheating taking up the place in the print head. The overheating in the printer can stop the printing to take place. This can become a frustrating factor for a user.
Solution to fix Canon Printer Error E02:-
1. Switch off the printer.
2. Soon, open up the print head.
3. Switch on the printer to make the process further.
4. Following this, you will see the ink cartridge will move from the right to the left.
5. When the ink cartridge moves, closed the printer cover.
6. To Continue Reading check this Blog- Canon Printer Error E02
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
1helpful
E04...how to setle it
That error means that an ink cartridge is empty. To cancel printing, press the Stop/Reset button. To continue printing, press the OK button. After the printing finishes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause machine malfunction.
You can read more about the error codes on Canon website: http://support-au.canon.com.au/contents/AU/EN/8000137001.html
2helpful
49.4C02 error is coming on Hp laserjet 4345 printer already latest firware updated.recentely changed printer motherboard also.
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. get more information and help Printer Error 49.4c02
Engine LSU error, printer will not print. Accepts paper half way then it stops.
lsu stands for laser scanning unit. it tansfers the image onto the transfer drum, common problems are horizontal sync, i would suggest a replacement lsu
I am getting a n error that reads "Pen Error"
Sounds like you have the print que setup to look for a Plotter there is no pens in the Inkjet
Find the proper printer when you go to print.
2helpful
2answers
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Error msg status 1
    sounds like a communication error, are you wireless?
    try connecting direct.
    Motor throtting
    This error appears when the printer has worked for more than 1 hours continuous, and to protect the printer. Wait a few minutes for printer to cool and continue with your printing.
    Top Minolta Office Equipment & Supplies Experts
    Norman Weimar
    Norman Weimar
    ZJ Limited
    ZJ Limited
    Daniel Blask
    Daniel Blask
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
