Help me to remove child lock to hisense tv model TC1495U
Unfortunately, I'm going to need some further information from you to answer your question. I think the model number you provided is actually the model number of the Hisense remote control and not the model number of the TV. The correct model number should be located on a sticker on the back of the TV. Please can you check this and correct if necessary. I'm not saying you are wrong, but I cannot find any existence of TV model number EN-30505A.
This is where it gets a little confusing. If that is the model number of the remote control then you should be able to disable the childlock by pressing the lock/unlock button on the remote . . .
Please can you reply to me with the following information:
1. The model number of the TV;
2. Do you have the original Hisense remote and is it working?
3. The approximate age of the TV (to assist with identification in the absence of a model number);
4. The brand and model number of any remote you are using with this TV;
5. Is there a MENU button on the front or side of the TV and does it open the on-screen menu?
6. Is there a MENU button on any remote you are using and does it open the on-screen menu?
7. How did you engage the childlock? (if known)
If you can let me know these details, hopefully I will be able to solve your problem. You should note that some Hisense TVs can only be unlocked with the original Hisense remote. It is possible to lock and unlock them from a universal remote, but unlocking them this way is dependent on remembering which buttons were pressed to lock it. Obviously this isn't possible if it was done accidentally/unknowingly!
Regards,
BElectric.
No problem - I thought it was the remote number, but I couldn't match it to a specific model of TV. Thanks for all the details. I don't need to know anything else. As you have the original remote and it's working, unlocking shouldn't be a problem. I just need to check a couple of things. I will get back to you shortly. BElectric
My apologies - there is an ongoing technical fault at FixYa which prevents me writing more than a couple of lines. I will try again now. It it doesn't work, I will break it into small chunks.
OK. It's easier getting information on the currents whereabouts of Arc of the Covenant than it is to get information for your TV. I could just about confirm the existence of that TV model number and I could find absolutely nothing anywhere to match the model number of your remote. However, I think I have
There should be a button in the top corner of your remote marked "F" or "FUNCTION". If you have this button, hold it down and then press MUTE while still holding F down.
If you don't have the F, button, switching off the child lock should be as simple as holding down the "DISPLAY" button on the remote for about 10 seconds.
If you have neither of those buttons, please can you check the model numbers - particularly of the remote - and get back to me.
Thanks,
BElectric
hy my tv also says child lock,the remote numbers is EN-30505A.The problem the buttons are not clear.so please if you can tell me wich buttons or what button colour to press
The model of the TV is TC2119U. It is a 54 cm coulor TV about 3 or 4 years old. I still use the original remote control. The menu button is on the side and under normal condition it give you all the options you needed but now it ain't do nothing when I press the button on either the remote control or the TV. The only when you turn on the computor it has a blue screen and written in read " Child Lock". Sorry for the previous model number it was the remote control's number.
Is there still no sollution? I didn't year anything from you the last 24 hours.
Thanks, I will wait patiently.
OK, I sort it out. I will give you a short discription of the remote: Left upper corner- Mute (green), Right upper corner -Power on/off(Red), then follows numbers 1-9 in 3rows, under the 7 (-/--), under the 8 the 0, under the 9- ALT, In the center a green buttun- MENU surrounded by VOL UP on the right, Vol down left, CH up top and CH down bottom, On top of VOL down button (Picture), on to of VOL up button (P.MODE), under the VOL down button (SYS) and under the VOL up button (CALL). The last button is on the left under SYS button and is the TV?AV button(Red). What I did was I switch the TV off with the remote and then I switch the TV off as well. Then I unplugged the TV and leave it for about 1 minute. I then plugged it in again and switch it on , TV first then remote. The CHILD LOCK came on again. I then Press the CALL button and hold it in for about 10 seconds and the unlock message appear. I then have to search for the channels again on the menu. Thanks for the help, I hope the info I provide you with will help someone else in future.
