2006 BMW 5 Series Logo
Posted on Feb 04, 2011
Will DIY changing your battery in a BMW 530 XI cause the electric systems to be reset at the dealer? Have seen that this is necessary with BMWs with X Drive
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Feb 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
15666
Points
53
The battery needs to be registered to reset the energy data that is stored in the vehicle.Without this being done you may run into short battery life and possibly energy consumers shutting down (ie the blower not working at full speed)
I have a 2007 530 xi and will not run without spraying it. Has only 9.5 volts to the fuel pump during cranking
The voltage is ok, maybe the pump's fuel pressure check valve is defective and the fuel pressure bleeds off and that causes a hard start.
Code 01 for BMW X3 2005 2.5i
I'm not a mechanic but have a few BMWs and have tripped the airbag light(s). As you probably know, the seats have sensors and are integrated into the system, and disconnecting them can trigger the light. Often you can avoid that by disconnecting the battery first, but that's water under the bridge (and doesn't seem to be 100% dependable). Good news is that there may well be nothing wrong with the system assuming the wiring is the same (and the connection is solid). Bad news is that for cars after 2002 or so, resetting the light takes diagnostic software (there are cheap SRS reset tools for the earlier cars). If you don't want to invest the time and cash to learn diagnostic software (i.e. INPA, etc.), I'd take it to an independent garage that works on BMWs and pay them to diagnose and reset it, or to at least reset it (NOT THE DEALER--$$$). If there's a problem, the light will come back on. Obviously, you don't want to fool around with the airbag system, so worth being extra careful and making sure it's OK.
Diagram for 2007 BMW 530 xi
"Diagram?" Really?
PLEASE BE MORE SPECIFIC. WHAT DIAGRAM??????
Also, try doing a Google search to find what you're seeking.
Electrical problems
Modern luxury cars have very complex computers that require a certain amount of energy to maintain the memory. At autoparts stores they use a device called a memory minder when changing batteries. it is a 9 volt that keeps the computer from resetting when the battery disconnects. I had a friend with a bmw 7 series and he disconnected the battery without a memory minder and the car wouldnt work right. idling low no idrive navigation system, no acceleration, etc. many car computers will relearn the necessary lost data after being started and turned off a few times 4 to 6. I have done this for many cars and it had worked on newer fords, jaguars, bmws, and others.
2answers
How do you reset the service engine soon light on a 2006 BMW XI. Itwent on due to a faulty gas cap which I replaced but the light stays on.
Unfortunately, BMW is a pain - in -the - **** and only a BMW dealer or an independent shop with BMW tools can reset this.
530i will not start but lights and radio work
Nice car.
Enough power to run the lights and radio is not necessarily enough power to crank the engine over. You did not mention the year, but on a 530, if this is your original battery, you are probably due for a new battery. I suggest that you borrow another car and attach it to the jumper cable connections under the hood (key in Off position on both cars) to keep your 530 computers powered up while you replace the battery. It is not critical to do this on a 530 as it is on the newer generation BMWs, but it is not a bad idea.
Unless there are a LOT of BMWs where you live, the group 94 battery size will be hard to find, and when you find one, it may be quite stale from sitting on the shelf half-charged for months. Most of us choose a smaller, group 48 battery. You have to put a spacer under the battery clamp, but it is a common size so it will be fresh and it will cost less.
If you really want the larger size, a group 49 'should' fit in the hole and is a little more popular than a group 94. It will be tight.
Re: air bubble in my bmw 325 xi coolant. Is it harmful to the engine to drive it about 147 miles back home before I get it bled out?
BMWs are very sensitive to overheating, can get very expensive. Bleeding the radiator takes a minute of two, A straight blade screwdriver, just slowly unscrew plastic screw until anti freeze begins to stream out.
2007 530xi Sports Wagon: where is battery located on 2007 bmw 530 xi...
If it's not under the hood, then the only other place BMW places their batteries is in the trunk. Since it's a Sport Wagon, pull up where the rear spare would be and it will be there, usually on the right hand side.
Hope this Helps,
~00 Buck~
"Still living on the Right Side of Dirt..."
I changed my oil in the 530 xi 2006 how can
your owners manual will have the instructions for that
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
