SOURCE: LG flat panel plasma with red line
john sellers you are da man!!! I ordered the 38C Board from Parts.com ($130.75 shipped--received in 2 days) and followed your perfect instructions and pictures. It took me 1.5 hours (no problems) and the TV is like new! Thank you, thank you, thank you!!!
SOURCE: thin red vertical lines on left side of 50
this is not an easy fix. the screen ,or the x or y screen drivers are bad .
SOURCE: bottom half of screen goes black, what could be wrong?
Loose connetion on the Y-buffer board.
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
