Nikon Coolpix S3000 Digital Camera Logo
A
Anonymous Posted on Jan 28, 2011
First it was giving a lens error and would shut off. tried charging it and now it wont work. Only have had the camera since christmas.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Sep 01, 2012
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444251
Points
622693
Try the procedures in this tip.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Apr 10, 2009
SOURCE: LENS ERROR
there does now seem to be a problem with these particular cameras. i work in a camera shop and have had a number of these returned to me with the same problem you all seem to be having. i have now been told that they are no longer being sold by nikon and you should all return them to place of purchase for a replacement or refund. even if you have no receipt your approximate purchase date can be obtained from the serial number. good luck
venugopal durairajan
  • 464 Answers
  • Posted on May 13, 2009
SOURCE: lens error
if the problem is due to the fact that u have dropped the camera on floor or put into water...then no other go you should change the whole lens array...contact your nearest service centre
Anonymous
  • 11896 Answers
  • Posted on Aug 28, 2009
SOURCE: lens error
You can send this to manufacture and they will repair it for $50.
Unless you get lucky enough to find parts on ebay, let me know.
Anonymous
  • 2761 Answers
  • Posted on Dec 28, 2009
SOURCE: "Lens Error" on Nikon Coolpix S230
Sorry, but there's no simple DIY fix, and any homebrew repair attempts will likely make the damage worse. Your camera's warranty won't cover the damage, so I suggest that you take it to a local camera shop (NOT the camera department in a chain store) or contact customer service via the nikon.com web site to arrange repair. Be sure to get a firm price before you commit to anything though. The fix can easily approach the price of a new camera, and repairs typically only carry a 30-day warranty.
Anonymous
  • 11967 Answers
  • Posted on Jan 19, 2010
SOURCE: nikon coolpix s230 lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
I bought my camera Christmas Eve, and a new memory card Christmas Day. Yesterday, I tried turning the camera on and the lens opened and shut automatically and said Lens Error with a Large Red Exclamation...
Many people have a Lens Error. Usually a tiny piece of dust or sand gets caught in the lens mechanism. PLEASE search for Lens Error here you will find MANY step by step procedures.
I just got a canon powershot sd 1400 is for christmas and i charged the batttery and then put it in my camera and automatically came up was lens error automatically shutting down
Make sure that the battery is charged fully. It may not have enough power to operate the lens on startup. If the battery is charged fully, and it keeps doing this, take back the camera tomorrow to the store that you bought it from.
For others reading this, that did NOT just receive a brand new camera that you can take back to the store. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try. (jillmur3, don't try these. take yours back to the store)
2helpful
My camera will turn on then shut off a few seconds after even if it has been charging for an hour whats wrong?
Most likely the lens is jammed or stuck. The unit is trying to initialize, and not being able to, shutting itself down. Dust and sand can work it's way into the lens assembly, and jam the gears. You can try to spray it out with compressed air to try and free it up. If that doesn't work, here's some things you can try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The page is for lens errors, but it applies to your problem.
They say about 50% of the cameras with a lens error/shutdown problem can be fixed.
Good luck, thanks for using FixYa, and hope this helps.
Samsung PL55 is not working. Help Please
Wiggle the lens a bit, it should be just a little off centre, it may not work emediatly but try and it will work!
Feb 13, 2010 • Cameras
21helpful
2answers
My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Camera gives E18 error!!!
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
1helpful
2answers
Lense error, restart your camera
If i told you to smack it around a bit would ytou believe me?
But that is the fix Canon use to get rid of these errors 98% of the time.
Charge or change the battery, insert it tuen camer on when it goes off smack it hard into your palm a few times and turn it back on.
Just incase there is some dirt/dust stopping the lens from extending blow a can of compressed air around it and give it another few slaps . Sometimes after about 20-30 ngoes of this the camera will jump back into service Believe me it does work nearly all the time Canon charged me $90 to do this trick
1helpful
Says lens error restart camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
1helpful
Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
15helpful
15answers
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
