SOURCE: caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me. I only needed a temp
setting/off switch to fix mine.
SOURCE: Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
SOURCE: Lakewood space heater thermostat source
If it is a Ksd31 thermostat you need, you are in luck. I found what I needed for my model 5600/7 on ebay. The store Larksining sells the for as few as five/pkg in various temp. settings. I got 5 ea. in two temp settings for less than $11.00 USD with shipping from Hong Kong.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
