'97 tiger wont start, I mean it wont even give a signal of starting when the ignition button is pushed, light , horn, pannel light all work , just wont start , after a 200Km ride left it parked a week and when I tried to start it it just wont give anny sight of life? is there an ignition fuse?
Harley horns fail. Replace the horn. If this fault has happened at the same time as engine wont crank then problem with wiring. If not then check starter relay (grey one). Also check ignition switch. Are the head lights coming on when turned on? If so the ignition switch is o/k. Connect a voltmeter to horn to check horn circuit. Accessory fuse 15 Amp supplies horn circuit and brake light and turn signal circuits so if these are working fuse o/k. Ignition/start circuit requires system relay and ECM fuse to be o/k. If fuel pump operates when run switch is activated then system relay o/k. Check start relay and circuit to start button.
firstly make all the bulbs glow in the indicator segment. this will moderate the flasher speed as due to even one bulb fused, causes other bulbs to glow at high rate.
Lift the tank. Underneath it you'll find a plastic connector block joining loads of wires together. Turn the ignition on and push this connector block together, or twist it around a bit. If the ignition sequence starts, it'll be because the wires in the connector block are corroded. Moving the block sometimes makes a temporary fix, but ultimately it'll happen again until the block or the wiring harness ideally, is replaced.
Look for a bad ground connection inside the headlight shell (or possibly elsewhere). The other thing that all of the items you mention that are working intermittently have in common is the ignition switch. With the switch 'on', check for battery voltage at the fuses for the headlight, turn signals, horn, etc. No voltage at the fuses likely means a bad ignition switch.
