push and hold any two buttons until you here a beep or push and hold the stop start button for same,this is a reset sometimes it will take about 20 seconds of pressing to reset,adrian...
Try this.. Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
The
control board has detected an error. Press any button to wake the
machine then wait for 5 seconds. Press and hold the START/PAUSE and
CANCEL buttons simultaneously then the failure code will appear in the
letters as long as the buttons are held. The control will beep and the
Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post
back the code for further advice.
I would check that the front is secure. My old front end loader would kinda do the same thing. If I didnt have the door exactly shut it wouldn't start. Start there hope it helps
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
