Getting check sp wires and protection circuit shuts down reciever..checked and ohmed out all sp wires.. all ok. Reconnected still shuts dowm same note ..check sp wires. next steps?
If you checked wire carefully in high ohm reading and confirm no internal short circuit.-please follow me:-1-disconnect all speakers cables from receiver and check if it is fine-try to connect your speakers one by one until you find the bad one.if it is still shut down you will have a problem inside receiver itself and needs service center to fix.
-it maybe speaker check it also one by one with good known cable.
There is an internal short that is being detected. This is probably a defective output transistor that is somewhat sensitive to heat. This should be a straightforward repair with a parts cost in the $20 range. Add in the local labor rate for the total cost.
Dan
1. With the receiver in standby, press STANDBY/ON while holding down the SPEAKER IMPEDANCE button.( Each time you do this, you switch between the impedance settings: )
SP 6 OHM - Use this setting if your speakers are rated at 6 Ohms
SP 8 OHM - Use this setting if your speakers are rated at 8 Ohms or more
You are not able to connect speakers with impedence bellow 6 Ohms with this receiver. Becuse the AV receivers impedence range is 6 - 16 Ohms.
Check sp wire
shuts off by itself
i checked my relays fueses ok when i start the engine i check the red wire going to the steering no cutent i checkedfor broken wires checked plugs in for bent pins no luck
