Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red and green light flashing on 5 of my bl11830 battaries and they will not take a charge
Repair Ahjoshe
Level 3:
  • Makita Master 885 Answers
  • Posted on Jan 20, 2011
Repair Ahjoshe
Makita Master
Level 3:
Answers
885
Questions
0
Helped
642945
Points
2112
If you put a battery on your charger and both red and green lights flash it is indicating that battery is defective. There may be a short in the battery or they just may be too old and worn out to charge anymore. If the charger is reading the battery as defective it will not charge the battery. The only fix is to buy new batteries.
RIDGID: 18V 8.0 Ah Rapid MAX charger flashes red and green at the same time. Why is this please?
Question edited for clarity and correct spelling of the maker.
Here is the manual section on the LED Lighting sequence. Both Red and Green flashing is not there. Your charger has a model number on the bottom of it and you didn't supply that, so this may be the wrong charger!
http://powertool.manualsonline.com/manuals/mfg/ridgid/140276002.html?p=5
The question was mentioned on Fixya before.
I have a ridgid rapid twin 18 V charger that flashes red and
Fixya https://www.fixya.com > Forum > Drills > Ridgid
Nov 21, 2019 - Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing.
My charger is flashing red when i place the battery in it - Fixya
Dec 7, 2010
Ridgid temp delay light flashing on charger - Fixya
Sep 2, 2019
My RIDGID Rapid Max Twin 18 volt charger, all it - Fixya
Aug 31, 2019
18v ridged rapid max charger flashes red and green same
Mar 12, 2023
More results from www.fixya.com
Mar 12, 2023 • Drills
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 • Vacuums
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 • Drills
2answers
What does it mean when my worx battery charger has a solid red light.
according to manualslib type site for the wg540, solid red means charging for the wa3840 and wa3838. After 30 minutes if battery has not reached 10 volts (of 18), the red will begin flashing meaning defective.
Just green? Ready to go. Green flashing? Overheat.
Tangent; sometimes a discharged battery needs a little coaxing - have to get a little voltage into the battery for charger to try to charge. Different company, electric drill. I plead ignorance if this applies for the 3840 since they mention the half an hour time.
1helpful
LED flashing green and red
I had the same thing happen to me with my pentax optio. You may have to large of an SD memory card. Or you could have the wrong type of card. I would recomemd that you use a 512mb SD card. Not the SDHC card. Also i would make sure that the battaries are fully charged. Hope this helps you out!
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
7helpful
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
3helpful
2answers
Does not charge,red flashing light on charger
Take a nine volt battery and put + to + and - to - for ten seconds and try to charge again if it does not work then you need a new battery.
6helpful
2answers
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
