20 Most Recent Casio Exilim EXZ75 Digital Camera Questions & Answers
Not powering on
The manual indicates that the green light flashing once indicates that the camera is powering down. http://www.manualnguide.com/dl/6597/ (see page 218 lamp indications) The first thing you can try is to turn off the camera, remove the battery, remove the memory card. Hold for one minute , pop the battery in(but not the memory card) turn on the camera by pressing the power on buttn and holding it for 15 seconds. This will not only reset the camera but also force the motor to retrace/extend the lens if it is a lens related issue that is causing the camera to shut down. Let me know if you need more help
6/4/2017 11:25:38 AM • Casio Exilim... • Answered on Jun 04, 2017
VER 1.00: can't navigate with the up, down, left & right keys
Some cameras, as well as having the main battery, also have a 'button-cell' type of battery that holds the system information such as date and time etc. I know not whether yours is one of these, but it should tell you in the manual
3/28/2017 9:49:31 AM • Casio Exilim... • Answered on Mar 28, 2017
0answers
Cannot download pictures to my computer from my
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
10/5/2014 1:53:31 AM • Casio Exilim... • Answered on Oct 05, 2014
0answers
0answers
3answers
I accidentally delted my pictures
after formatting the memory is deleted for good and there is no way to get them back ..If they were in a SD card ..you may try with a recovery software ..but almost never they get recovered after formatting ...when you just delete them there are chances for some of them to let a trace ..but when you format a memory unit you practically delete and rearrange the memory unit size again ..(alocation ) ..and there can not be anything left ..
12/6/2013 3:02:25 AM • Casio Exilim... • Answered on Dec 06, 2013
2answers
Charging problem
solution magique
vous avez besoin d'une pile carré de 9v 2 file électrique
branché le (-) de la pile avec le (-) est le (+) avec le (+) de la battrie environ 20 seconde est réessayer.
12/5/2013 9:40:29 PM • Casio Exilim... • Answered on Dec 05, 2013
2answers
Deleted pictures
Unfortunately, when the card is formatted, all data is erased. There is no way to get back the pics you had on it earlier. Sorry..
11/5/2013 1:41:58 AM • Casio Exilim... • Answered on Nov 05, 2013
4answers
Camera formated sd card with
Hi, gschlatt. You have great chance, do not miss it. It is quite possible to recover the photos no matter deleted, formatted, lost or inaccessible from your sd card. All you need to do first is by trying SD card recovery software tools. Note: before those files are recovered, never should you attempt to save more data to the card. better stop using it for a moment. Hope it helps. Regards.
9/26/2013 1:49:44 AM • Casio Exilim... • Answered on Sep 26, 2013
Transfer photos computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
5/25/2013 7:43:43 PM • Casio Exilim... • Answered on May 25, 2013
2answers
Casio Exilim EX-Z75 Digital Camera Trouble
Main board is faulty and requires replacing.
Must go to a Camera repair shop to rectify the issue.
10/16/2012 2:05:09 PM • Casio Exilim... • Answered on Oct 16, 2012
I cannot upload the pictures to the computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
8/27/2012 4:34:16 PM • Casio Exilim... • Answered on Aug 27, 2012
How do u charge a canon sd600
To be precise, you don't. You take the battery pack out of the camera, put it into the supplied CB-2LV battery charger, and plug the charger into a power outlet.For full details, refer to the battery charging instructions on page 3 of the Basic Guide.
5/7/2012 7:49:39 PM • Casio Exilim... • Answered on May 07, 2012
" The card is locked.
9/18/2011 11:26:57 PM • Casio Exilim... • Answered on Sep 18, 2011
2answers
The lens mechanism is partially extended and locked in place/
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
9/17/2011 6:57:09 AM • Casio Exilim... • Answered on Sep 17, 2011
How do I manually re-set
Press MENU. On the "Set Up" tab, select "Adjust" then press cursor-right. Use cursor-left/right to move between fields, cursor-up/down to change them. Press SET when done.
The instructions are in the "Changing the Camera Date and Time Settings" section of the manual (page 165 in my copy), which discusses both the world time settings and the home city date and time. If you need a manual, you can download a copy from
http://support.casio.com/pdf/001/EXZ75_DI_e.pdf
7/14/2011 11:28:43 PM • Casio Exilim... • Answered on Jul 14, 2011
Casio Exilim EXZ75 Digital Camera Logo
208 questions posted
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
camera formated sd card
  • Cameras
