If you mean your windows administrator password is not working and you want to change it and want to boot in safe mode then use the option of F8 at boot time this should take you to safe mode of windows. You can also use Hiren Boot CD to change administrator password if you own that server. Hope this answers your question.
SOURCE: hp proliant ml370 g4 rebooting problem
Try to boot from smart start and do offlinr diagnostics.have you purchased second cpu seperately? Check the CPU compatibilities.
SOURCE: my HP Proliant ML370 G4
dear erwin,
as per your writing the server raid has broken .. its may be a problem with a hard disk , first you have to check the hard disk state . to do that you should enter into raid bios . don't try to something on that , just see the status of logical drive then which are the disks includes on that raid
in you post also it may give the details of failed disk ids
then you may have problem with your batt. unit , for that please do the above steps first then back with that...
SOURCE: graphic drivers for hp proliant
Driver available for download at the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=3186395&prodNameId=3279681&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-0f11b3d202cc4fccaa0cbbb094
Here is a
simple way to access Windows XP with Administrator rights and privileges if you
have password protected your User account on your Windows XP system and can't
remember the password(s) to login. Whenever Windows XP is installed on a
system, it creates a default account called "Administrator" and by
default this account is not password protected. Therefore, if you bought a
brand name computer (such as Dell, HP, Compaq or Sony)or you have installed
Windows XP yourself. You should be able to login to the computer through the
unprotected.
You can log on as an administrator to assign a
new password to your account. To do this, try Method 1.
Method
1:
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button
after you switch on until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Click through several self-explanatory
screens until your reach the familiar 'Welcome' screen.
Note that
this welcome screen is limited to 256 colors and 640x480 resolution because the
primary graphics will have been set to the Windows Safe Mode software VGA
adapter. You will not be able to change this mode even in Display options,
while Windows is running in Safe Mode.
Find
the icon for the Administrator user. If the default settings of your system haven't
been changed, there should be no password for this account.
Continue on to the User Settings control panel. Here you can change any
of the other passwords for user on the machine. Make any changes you want.
Reboot your computer. As long as you don't
press any keys (e.g. F8) during the boot-up the
computer will startup normally.
