Opteka 650-2600mm High Definition Telephoto Lens for Canon EOS/ AF Logo
Posted on Jan 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I like to take pictures of wildlife, would this be a good lens to get great wildlife pictures.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jan 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
1134
Points
8
YES JUST USE A GOOD POLARIZING FILTER AND A CPL OR ND4
Tony Parsons
Level 3:
  • Opteka Master 6,405 Answers
  • Posted on May 19, 2016
Tony Parsons
Opteka Master
Level 3:
Answers
6405
Questions
Helped
1652305
Points
20272
For a lens of that size and weight, you will also need an extremely sturdy tripod and a cable release to eliminate camera shake.
2answers
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
2answers
Blurry pictures of moving wildlife
check shutter speed, problem to slow, increase aperture if light level permits hand shake can also blur image.If in full auto mode change to manual settings mount camera onto tripod THIS WILL SOLVE HAND SHAKE PROBLEMS the most common cause of blurred images.
3helpful
Please tell me the best lens and flash for D3100 i m not a proffessional photographer and i rarely go to see wild animals in forest. I want to click family photographs and natural beauty
hi there,
i used d3100 a few months ago,
for your information this camera only support autofocus with built-in motor lenses
if you have interest on wildlife, you should use tele-lens whose focal length above 200mm
if Nikon lenses cost you too much, you can choose other lenses from Tamron, Tokina, or Sigma
for family photograph, the kit lens is able to do this (18 - 55mm),
for natural beauty, i myself use nikkor 50mm/f 1,8 which has great power in low light condition
hope this will help
2helpful
2answers
I am only a starter. I have a 15mm-105mm lens kit lens
That's a question only you can answer. Both are fine lenses. What kind of photography do you want to do? The 50mm is generally better for portraits, while the 35mm will be better for landscapes. Neither is very good for sports or wildlife.
Zoom error
It sounds as though your lens is sticking while trying to extend. Check the lens to see if it binds. Also look at the retracted lens and see if the center portion is properly centered or is cocked to one side and out of alignment.
Once your camera is working properly, as you say it does at times, hold the camera with the lens pointed downward and run the zoom in and out several times to see if there is dirt caught between the lens cylinders. Sometimes that will work any debris out.
1helpful
Hi This is Mac from bangalore. Recently i bought a Nikon D80. I love to take wildlife & nature photography. what lens can u suggest. i already have a 18-135mm lens that came as a kit. would be great if...
Mac, you will depending on the type of wildlife you are wanting to photograph you will probably need something marked with at least 300mm on it. Nikon have lenses in this range at different price levels. I suggest that you maybe look at the 75 - 300mm, from memory it has VR on it... important for use at the 300 mm setting to help reduce camera shake. Cheers Ian
2answers
Focal length equivalents
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}I believe it is equivalent to a 35 to 210mm lens on a 35mmcamera. If you are considering a Nikon such as the D60, D80, D90, etc.,the standard lens sold with the camera is 18-135mm. This is not the sameas an 18-135mm on a 35mm film camera. The equivalent 35mm film cameralens would be 27-202mm (you multiply by 1.5), about the same as what youhave now. If I were planning to do wildlife photography, I would buy a usedNikkor ED 70-300mm AF lens on E-bay. You should be able to get one for$200 or less (the new price is $550+). This lens is designed for a 35mmfilm camera and is the equivalent of a 105-450mm when used on a Nikon digital cameras. Additionally, it is compadable with the automatic features of the Nikon digital camera bodies. This would give you an excellent portrait lens at 105mm and extra long reachfor wildlife. The fast shutter speed and stabilization circuit on thedigital camera should make it usable in daylight without a tripod. I havethis lens on a Nikon film camera and it is a superior lens. At a 1/1000second or faster shutter speed, I get sharp hand held photos.
Virtual tour
the picture is blurry due to lack of focus in the lens.
Im using a fish eye lens. my f\stop is 6.3 shutter is 30.
Im trying to due a virtual tour of my kitchen so its a big picture that i want all in focus. i have tried different settings on my camera but i think im making it worse.
Top Opteka Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Opteka Camera Expert? Answer questions, earn points and help others
