The 667 has two line level outputs to feed a subwoofer. They are identical. You only need one for most sub woofers. You need a suitable length pin audio (RCA) audio cable to connect.
Does your receiver have any kind of line level audio output? AUX OUT, LINE OUT or similar? If so, you might be able to send that a subwoofer. Most standalone subwoofers have their own crossover and level controls built in, so you can make adjustments there.
This is the exact same setup im lookng at, just a different Yamahareceiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
