Food Mixers Logo
Anonymous Posted on Jan 13, 2011
What type of grease can you use in your kitchen aid mixer, and also where can you buy it. Thank you.
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Jan 13, 2011
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1128283
Points
12184
KitchenAid uses Shell Darina #2 grease. If you're seeing oil, it's probably because the oil has separated, and should all be removed and repacked with new grease. It is available for sale for $4.20 per tube (14 oz). With that said, the official position from Kitchen Aid is:
Normally, your mixer has enough lubrication to last the lifetime of the appliance. If through some mishap ( mixer is tipped during shipping or storage) oil leaks from the drip ring or shaft area, it can be attended to at a local authorized KitchenAid repair shop. Losing a teaspoon or 2 is nothing to be concerned about, but if there's 1/4 cup or so lost, your mixer will need repair. You may feel free to contact us at Customer Service for the most up to date listing. Call 1-800-541-6390.
If you really want to get into this, a web page discussing this situation is posted here. Of course, disassembling the mixer will void your warranty.
I hope this helps. Please rate my reply "4 thumbs up" if you're completely happy with the info. Thanks!
Testimonial: "Thanks, is that grease non-toxic?"
  • Steve Jan 13, 2011
    It is rated for the application. The Shell Darina 2 is a mineral based lube, and small amounts ingested won't be a problem, large amounts would be a different story. Use of petroleum oils is discouraged. You can read more about Darina 2 here:
    http://www.epc.shell.com/Docs/GPCDOC_TDS...
    I searched for Darina 2 and the links I got and pasted was for Darina SD 2 and Darina R 2. The Darina 2 is available here: http://tinyurl.com/4f78yn6 Please disregard the link for the $4.20 tube. I don't know what the difference between "2" and the other two (SD 2
1 Related Answer
Anonymous
  • 58 Answers
  • Posted on Feb 02, 2008
SOURCE: greasing a mixer
I think this link will help you understand what is needed to fix your mixer.
You need to replace some grease, but make sure to use a non-toxic food grade grease.
Kitchen Aid Mixer. How to fix a grinding sound when switch is on Medium speed?
Question edited for clarity.
The drive train probably need cleaning and re-greasing, but there is also a gear that wears out.
https://www.google.com/search?q=Kitchen+Aid+Mixer.+How+to+fix+a+grinding+sound+when+switch+is+on+Medium+speed
Dec 26, 2023 • Food Mixers
2answers
Where can I get the grease for my Kitchen aid stand mixer?
The grease is food grade grease and Kitchen Aid supply it as a spare part so depending on where you live either from themselves or an Authorised Service Agent. If you are in New Zealand then I can supply.
I dont know what else to add other then the oil came out of the mixer when i moved and i do not know what type of oil to put back in it and where do i put it in to the mixer on my kitchen aid mixer
Wipe the oil off and carry on. Over time the gearbox grease breaks down and oil separates from the grease solids. Eventually the gearbox will need to be repacked with new grease. Don't worry about a drip or two in a cake, it's food grade grease so harmless.
2answers
Can i replace the original grease in my kitchen aid mixer with lithium grease?
You can use Lithium Grease as long as it is Food Grade. It almost always will have the NSF logo on it.
May 02, 2011 • Food Mixers
1helpful
4answers
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
1helpful
2answers
Kitchen aid growls at slow speed
Hello again, BCPSBT. I’m sorry, but I’m just a little confused because neither the Part List nor the Owner’s Manuals go into any detail about changing/replacing the lubrication grease in your mixer, so I’m not sure what you are referring to when you say your system ‘times out’ when you get to page 10 when you attempt to download it?
The Parts List manual is only 8 pages. Are you perhaps attempting to download the Owner Instruction and Recipe manual instead, which is much longer?
The reason you need the Parts List Manual K45SSWH-0.pdf (2730.37 KB) is to see the ‘exploded views’ which will aid you in the disassembly and reassembly of your mixer. The best instructions for regreasing you mixer are from these two websites:
I’m sorry I don’t have more specific step by step instructions to offer you. Sometimes you have to step out in faith and trust that you can actually accomplish the work yourself.
I wish you good luck in completing your ‘oil’ change.
Good luck and have fun. I hope this provides a little more clarification. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Turned over and oil leaked out. Not sure how to replace and with what type of oil. Thank you.
There should be no oil. It is probably grease that has leaked due to a gasket not sealed tight. Go to Mendingshed.com and if you type in Kitchen Aid Mixer you can find a manual that shows what type of grease.
3answers
Food made with KitchenAid Stand mixer tastes like grease
The likelyhood of grease coming from the mixer is extremely small. As long as the beater & bowl were washed first and the shortening you used was fresh, there shouldn't be a grease taste.
2answers
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Top Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Food Mixer Expert? Answer questions, earn points and help others
