Hello
The memory can be expanded to handle more data with a 2GB SD (Secure Digital) Memory card installed in the memory card slot, have you done this?
You will need to buy a memory card, there is no other way to expand the devices memory, this is the same memory card that Digital cameras use, it just plugs into a memory card expansion slot (consult you user manual for location), cost is less than $15.00 at any electronics store or camera shop.
Here is the memory card.
The picture is about the actual size
I have one correction, this model uses a Micro SD memory card, up to 8GB on your model, the slot is located on the back of the scanner, it is clearly marked. Here is a link to the user manual, the page that shows the memory card slot is is 1-3, please allow for time to download load the pdf file.
https://docs.symbol.com/manuals/11299803...
Here is a picture of a Micro SD Memory card.
The memory card is device two by the way.
No, no additional card.
I would like to copy the file to the "Application" storage without adding hardware.
I'm not sure on what to delete to make room i.e.: What is required by the system to work.
Thanks emissionwiz. I already know for the expansion slot.
But I want to know if it's possible to configure (by software) the device to allow more space in the Application folder.
If not, what are the non required files I can delete without compromising scanner operations.
