I could find nothing on the Dp313 but according to the Dp315 you can't reset, at least not according to the manual. It says: Change Password Move the cursor to the change password item and press enter button to confirm and then input secret code "8888" (if it is first use). After confirmation, you are required to input new secret code and then press enter button to confirm. And retreat the custom setup interface.
Warning: Please remember the new secret code, otherwise you will not be able to change the parental ctrl. Please contact the agent or our company once you forget the secret code.
1Put the screwdriver into the screw hole in the small panel on the back of the Leapster. Remove the screw, and open the panel.
Remove the batteries from the Leapster and discard them. Find the small "reset" button behind the panel cover. The reset button should be black or red
Press the reset button with the pointed object. Hold the button down for about three to five seconds.
Put fresh batteries into the battery chamber. Make sure the flat side of each battery connects with the springs in each battery channel. Screw the panel cover back into place.
5
Press the Leapster's "on/off" button. When the Leapster comes on, enter the country information and the player's name.
6
Press the "hint" button, which opens a pop-up help menu. Press the "A" button. Use the stylus to touch the center of the small crosshairs on the screen to calibrate the touch screen.
Reset the Leapster pushing the small black button that says "Reset" which is located behind the batteries in the battery compartment. Once your Leapster has been reset, you should be directed to the first-time screen, where you can set your country/region and enter the player names.
Here is a method to unlock the LG Secret easily and safely. LG Phone Problem and solution
1. insert original sim card and turn your LG Secret on. LG-Secret info
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
4. Enter your unlock code and press ok
5. The LG Secret will then reboot and the unlock is complete.
Push the "A" button to enter the calibration. There will be a little
plus sign. Touch it with the stylus and continue to touch the plus
signs with the stylus until you return to the calibration screen. Turn the Leapster off and then back on again without a cartridge.
type 5813 0790 4610 4973 in the "Have a bonus code" area of the Leapster Explorer Leeplet Store splash page. You'll get a free Alphabet Stew download. My 4 year old is having a blast right now! -->
