LeapFrog EnterprisesVisit our customer support page for LeapFrog's Leapster 2 for help and answers to your product questions.Missing: electronic board
35 mins ago - ... 2 electronic board? I know how to solder and basic principles ofelectronic parts. Know - LeapFrog Leapster 2 Learning System question.
iFixitDrained/bad battery; Bad display; Water damage; Bad logic board ... Instructions toreplace the battery can be found at LeapFrog LeapPad2 Explorer Battery ...
? 3:02
https://www.youtube.com/watch?v=eQayGCjEdgo
Jan 22, 2009 - Uploaded by filterdragon
Tutorial on how to fix your child's Leapster 2. If your Leapster 2has a problem other than the screen not registering the stylis pen, please go to the Leaps... ... Ana E 1 year ago .... 2:34. leap frogleappad repair guide.
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
run a toothpick around the screen under the plastic frame and pick out dirt, food particles etc. and see if this helps. Do it very carefully not to damage the screen.
Have you tried to upload it to the computer? Sometimes they get too much information on them and won't work. Are all of the connections to the batteries cleaned? Sometimes, also, there are bad connections between the machine and the batteries. Hope this helps.
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Turn off the Leapster2 and remove cartridge (if there is one). Push and hold down the hint button (the one with the question mark) while the game is off. Turn the Leapster on while still holding down the hint button until you see the calibration screen. Push the "A" button to enter the calibration. There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen. Turn the Leapster off and then back on again without a cartridge. Login as usual. If this does not work, then call customer service, depending on how old it is. I've had ours for over a year, and this still works each time.
Did it come with the batteries installed or seperate? Make sure they work in another device after they charged for 24hrs.
sometimes there is a seperator tap inside that needs to be pulled out
chadman
1) Please run the LeapFrog Utility http://lfccontent.leapfrog.com/cs/utilities/LeapFrog_Connect_Utility.exe2) Select "Clear LeapFrog Connect User Data"3) Start the LeapFrog Connect application and wait until the message center indicates that all Leapster Explorer Updates have been downloaded.4) Power on and plug in your Leapster Explorer.
open your leapfrog connect and plug in your device to ur pc. click on ur child's name. on the left at the bottom you'll see "on this device" click it, it'll show u a list of what's been bought/downloaded onto the leapster, you can fix it from there I had the same problem 2 weks ago and this is how I fixed it. and if it's not showing an app that you purchased at the very bottom there's a clicky "check for new dowloads" just in case... and here are 2 free codes for you: book 5813 1140 1518 1413 (might be 1314... sorry) game (alphabet stew) 5813 0709 4610 4973 hope they still work....
