SOURCE: Hi! i have a life fitness 9500HR treadmill and it
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
SOURCE: I have noticed a few times that my f3 life fitness
It might just need a simple adjustment of the running belt that can eliminate the slipping refer to you owner's manual for the procedure. It will be close to all treadmill adjustments.
Here is a generic procedure for adjusting the belt:
If the walking belt slips when walked on. Run the treadmill @ 3 to 4 mph, walk for a few minutes, Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. Then repeat adjusting procedure until walking belt is properly tightened.
SOURCE: my life fitness f3 treadmill wont incline anymore
I am having the same problem as well!! Can anyone help?
SOURCE: I can't increase the incline
You can get the manual on the link below to see how to increase the incline.
http://www.lifefitness.com/static/cms_workspace/manuals/F3AssemblyInstructions_12-15-06.pdf
Good Luck
