Razor E300s  Electric Scooter With Seat Logo
Posted on Jan 11, 2011
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
Ken Hackenberg
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Oct 30, 2013
Ken Hackenberg
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
5021
Points
38
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Shoprider Mobility Scooter. My chair is a shoprider. I ran into 12 pack of soda and the scooter wrench is blinking and the lights across the top are blinking.
You can try pressing the reset button, or disconnect the battery for 10 minutes.
Shoprider Scooter User Manual
Eden Healthcare Solutions https://www.edenhcs.com.au > files > Shoprider... PDF If your scooter does unexpectedly stop then turn the key off, Wait for a few seconds and turn the key back on.
26 pages
Push the reset button. If the Powerchair / Scooter still doesn't turn on, check the condition of the batteries and the battery fuses located in-line with the battery cables. Under the seat and shroud are the batteries.
FAQ - SHOPRIDER Mobility Products
Shoprider https://shoprider.com > about > faq
Shoprider ECHO 3-Wheel Mobility Scooter. The driven wheels turn for a second, but then clicks out.
Question edited for a lot more clarity.
Question moved from Cars and Trucks to Make model category.
Is it tripping the breaker? If so it is likely an issue with the motors or the controller.
Circuit Breaker (Reset Button)
Your scooter is fitted with the latest in electronic controls that are programmed to protect
the electrical system from abnormal overloads. Provided for extra protection is a circuit
breaker, located on the battery pack. Should there be a situation where your scooter stops
for no apparent reason, please check that the circuit breaker has not popped.
NOTE: To preserve battery charge, your scooter may go into sleep mode after being idle for
a few minutes. To remove from sleep mode, turn the scooter switch off and back on again.
Check List
If your scooter fails to operate, please check the following:
ā€¢ Unit is switched on.
ā€¢ Drive/Freewheel mechanism is in the drive position.
ā€¢ All plugs and connectors are clean and firmly connected.
ā€¢ Battery level shows full charge.
If the free wheel device has been operated with the scooter switched on, then the scooter
will not operate until the ignition key has been switched off and then on again.
Please consult your dealer if your scooter does not run after checking these points.
Manual
https://www.manualslib.com/manual/461818/Shoprider-Echo-3-Sl73.html?page=14
More here
https://www.google.com/search?q=shoprider+echo+3+clicks+breaker+troubleshooting
Led power light on my Pride victory xl4 scooter will not come on when key is turned on. Batteries are charged and lights work but scooter wont move.
Check under the back end, generally connect to the electric motor is a lever by one of the back wheels, or in the case of "pride" sometimes they have knob that is lifted or dropped above the housing to engage or disengage the electric brake on the motor. If it is disengaged the scooter will not move by the motor, but you should be able to move the scooter manually, sometimes it gets "between" where it should be! If it is engaged, you shouldn't be able to move the scooter by pushing or pulling. Once your sure it is engaged, turn off the scooter wait a moment, then turn it back on. There is one more reason that may cause you a issue, the scooter can not be connected to the charge cord, disconnect it from the scooter and again turn off the key, and then turn on again to reset the scooter interface. These are both safety connections. Some of the newer ones will also "beep" if these situations are happening, and stop beeping when reset..
Pride Celebrity X mobility scooter just clicks when throttle is engaged. Green light flashes 4 times. What is wrong?
Hi again try this remove key & push freewheel lever into freewheel then push it into drive put key back & hope the control box has reset...PLUS CHECK THE BATTERIES WITH A LOAD TESTER available on E/Bay cost aprox $35 dollars .. flash code ( CURRENT LIMIT TIME OUT ) TURN SCOOTER OFF FOR A FEW MINUTES THEN TURN IT BACK ON ... cheers
1helpful
When I turn it on an alarm sounds and won't stop. The scooter works well except alarm won't stop. It is as if you are pushing on the horn all the time.
hi Irene, sounds like you got water inside the button you push to activate the horn, the push button will need be dried out ....either by disassembly's or carefully placing a warm setting hair-dryer near the button and operate to get the water to evaporate .. but don't do it too hot otherwise the button will start to melt...
Regards
Rob
Mobility scooter stops dead. I turn key off and back on it will go again then stop
Check your battery terminals are tight. It sounds as though they have come loose, or you didn't do them tight enough when you changed batteries. Perhaps clean the terminals both on the leads and the batteries, and finish with a wipe of Vaseline to keep water at bay. Good luck.
Dec 02, 2014 • Motorcycles
2answers
Have the phoenix s35015 scooter. The battery is charged, put it in the scooter and turn key. All power lights up to the green, lightsheadlight can come on and horn beeps when pushed. The red light does...
make sure you put it in "gear" completely sometime you can get it almost locked but its still in freewheel, flashing light is error code, do a count of blinks and stops, look in the back of book for trouble codes
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
1helpful
Freezes up while operating
I have found that my aiptek digital camcorder also freezes like this sometimes after I have pressed the button to stop recording a movie. You are right that sometimes you must remove the battery to unfreeze it, but I have found a couple of other tricks that work sometimes.
1. You can hold down the menu button for a few seconds (like 6). Sometimes this kicks it into the menu and unfreezes it.
2. Sometimes using the power button inside of where the screen stores to turn it on and then off again often helps.
3. Popping the digital card out (push in so it unlocks, then push it right back in) also helps unfreeze it for me.
If those don't work, pop the battery out again.
I do find that every few months I need to clean the connection points on both my battery and the camera where the battery clicks in. After I do this it behaves much better for a couple months. Good luck.
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
