Hi
Have you tried to use your computer when power charger is connected to power supply? Then try it to check if your computer does not shut down. If do not shut down it self. You had problem with the battery or with charger not compatible with the battery. Normal problem of shutting down computer is that your battery have no charge, your battery is not compatible with your laptop or ever defective. Tr
Same thing happens whether plugged into power or not.
I believe that problem is the charger, try another charger and it will work again.
If still not working, i suggest you reinstall your operating system and maybe it is corrupted and prevent you to boot up and shut it down. If your computer does not accept formating. Then surely the problem is your hard disk drive it damaged and needs to be replace with new HDD.
