Re: How long does it take to charge for first time
Well the first time charge is 18 full hours. but after i m not sure lol. in tryin to figure out how long you charge it afterthe first full time charge.
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
The first charge is - as you suspect - longer than the normal charge in order to "wake up" a battery that may have been on the shelf for a considerable time since manufacture. Typically 30 hours for the 2500mah batteries and 16 hours for the 1350mah.
I assume that your charger charges at a rate of 140 to 160 mA. This info is usually printed on the charger itself. (Quick chargers is a different story and the chargers are usually intelligent and can regulate the charging electronically.)
If your charger charges at a rate different to the typical 140/160mA, then increase or decrease the time for charging accordingly, i.e. reduce the charge time if the charge rate is higher. A good and safe test would be to check the batteries from time to time for heating. Stop the charging as soon as you find that the batteries are heating to anything warmer than a mild temperature rise.
1. A blinking light indicates that the battery is not charging. 2. The
steady light goes out (or turns green) when the battery is charged. 3. 6 to 8
hours for the initial charge. 4. Charging time after the initial charge depends on the length of time the
battery was used and will increase over time as the battery gets older. 5.
2.25 hours of play time
